configure mac-locking ports log
configure mac-locking ports port_list log {violation | threshold} [on | off]
Description
Enables or disables the sending of a syslog message for MAC lock messages.
Syntax Description
port_list Specifies one or more ports or slots and ports.
violation Sends a syslog message if the maximum value configured for dynamic and static MAC locking is exceeded.
threshold Sends a syslog message if the maximum value configured for dynamic and static MAC locking is reached.
on Sending a syslog message for the specified event is enabled.
off Sending a syslog message for the specified event is disabled.
Default
If neither violation nor threshold is specified, violation is used by default.
Usage Guidelines
When MAC locking violations are enabled, the device sends a syslog message if a connected end station exceeds the maximum value configured for dynamic and static MAC locking.
When MAC locking thresholds are enabled, the device sends an syslog message if a connected end station reaches the maximum value configured for dynamic and static MAC locking.
The following example enables threshold syslog messages on port 14.
configure mac-locking ports 14 log threshold on
This command was first available in ExtremeXOS 15.7.1.
Platform Availability
